My neighbor gave this old tiller to me. When I attempted to remove the gas tank, I needed to remove a spring that I thought attached to the governor arm. When I went to reattach it, I could not find a hole in the governor arm, to put the end of the spring into. Now I do not know where or how it attaches to. I can get it started, but it wants to run WAY to fast or go to slow. It is obviously not hooked up correctly. I downloaded a manual, but it did not show it. I looked at a parts diagram, but the carb diagram did not show it either. Anyone with a suggestion? The rear attachment is correct, it is where the front of the spring hooks to that I am need to know about.
Thank you STeve
Thank you STeve
