Ingersoll Rand DR250 Gyro Flo Compressor
I want to thank NCWayne for his help with my compressor.
Short version of the story is the unloader actuator diaphragm was trashed. When I finally got it apart, I searched for a truck air brake diaphragm. Finally cut a diaphragm out of a piece of 10inch dia PVC discharge hose. It works fine now...
It was good talking to you the other day. Thanks for the update. I figured it was something simple, but as I said, if it's not ALL working right, it's not going to work right. Glad you were able to find the problem and get it repaired as easily as you did.
hi. I also have a gyro flo. Having problems finding parts. Need replacement vanes. And trying to get it apart without breaking anything. Mime is a grr160 .any info will be apreciated
