Making A Jump Pack
guido
Hello,
First set of batteries are done, 4Volts 20 Amps. Second pack needs one. Third pack? I need to hit the recycle bin!
Guido.
Hello ztmower,
Besides saving batteries from the smelter, I think at 20 amp hour it will be better the my jump box. I may add a couple capacitors to the mix. I have had the question ask before. Usually I make up drill pack, and give most of them away to family, friends, barther, and anyone need onet free of charge,
GUIDO.
Guido, I enjoy and learn from your posts. Just a thought however. A neighbor had a fire that burned down his Hobby shop. It was started when one of his batteries he was charging for his RC plane overheated and burned. It has been suggested that when he gets re-built, that his charging station is on and surrounded by clay tile or some other fireproof material. Just a thought that might save some heartache. Keep up the good work.
Tim in OR
Hello Tim in Or,
I appreciate your concern. I have been using rechargeable since they first came out. First day of class for shop safety orientation, I would start with this: The best safety device is a careful man. If you are somewhat familiar with what you are doing,(listen and learn while you are here) it is a plus.
Guido.
Don't let anyone from Homeland Security see that or we'll be reading about the arrest of Guido The Terrorist.
