deadeye123
I have a 17kw Kohler genset tied in to my house. When it starts it will run real slow and after about 10 seconds shut down,flashing a code of low voltage. I assume the low voltage is because it is running so slow. It seems like it isn't getting enough fuel. I took fuel hose off at the LP gas regulator, PN A-227531 and I couldn't feel or smell gas when cranking engine.I unhooked supply gas line and it has good gas pressure. Gas cutoff solenoid clicks like it is working when power is supplied. I suspect the LP gas regulator is bad. The only one I can find online is $173. Not wanting to throw parts at it if not sure. Any ideas out there?
