Old air compressor identification and parts location
dkwebster
New User
Hello all, I'm new to forums and need some help identifying my pump. From what I have found so far, I think it is a par model 15, and need help finding either parts for my check valve or a replacement for it. Any help is greatly appreciated
Here are some photos if the upload
I am not going to be any help on this, but my dad had a Par; what year do you think yours is?
If there is an industrial compressor shop near you, the may be able to help identify it. Many times companies are sold/merge and the products are renamed. I see the name "Lynch" associated with that compressor, but nothing looks familiar.
The stamped number in the last photo would most likely be the model.
What is wrong with the check valve? Would cleaning it, freeing it up be of help?
What kind of problem is it having?
Generally the fittings on a compressor are made to standard plumbing fittings. You may have to do a little re-arranging but you should be able to get a check valve from most any compressor and make it work.
