10 dia saw blade
jimlll
I need to replace the blade on a 10" table saw. I would like recomendations on the number of teeth for a general use blade.
thanks in advance for your suggestions.
Jim
More teeth the finer the surface of the cut. Think it is called a plywood blade. Takes a little longer to feed but makes an almost perfectly smooth finish. If you are doing rough work then a GP blade is in order. Also want to buy a carbide tooth blade. VERY sharp but really last a long time. Next is up to you so don't feed any nails, staples, or such through it.
General-use (combination) blades usually have 40 teeth. They work reasonably well for cross-cutting as well as ripping. You can find them for less than $10 or as much as $100+, depending on brand and quality. You probably won't find fewer than 40 teeth; 60- and 80-tooth blades are common for smoother cuts (and higher cost).
The only blade I use is a dw3370 28 tooth, old school molly steel blade. It's cheap and it very easy to sharpen with a cheap HF circular blade sharpener for around $50. The blade is thinner than most carbide blades. Uses less power, makes a great cut.
Another feature, the angle of the blades is a simple setting. Once you get sharpener set up, it takes only minutes to sharpen. I've sharpened mine many times.
I have repurposed my blade sharpener as a drill bit sharpener. geo.
dw3370
A general use blade isn't really very good for either ripping or cross cutting. If you do much ripping at all, a special purpose ripping blade is worth the investment. Then you can get a second blade that's better for cross-cutting.
Any of the name brand blades with carbide tipped teeth are good. I'd avoid the bargain basement ones.
You really need two blades: A 24 tooth blade for ripping lumber and a 40 tooth blade for plywood and fine cuts. I've had good luck with Freud (Diablo) and Oldham blades.
Yepper on that. HF has/had them, last time I bought in both cuts, carbide tipped, for a song. I bought half a dozen and still have 4 (2-28s and 2-40s) left. What does that tell you and I don't sharpen my blades.
(quoted from post at 02:02:42 06/20/16)
Yepper on that. HF has/had them, last time I bought in both cuts, carbide tipped, for a song. I bought half a dozen and still have 4 (2-24s and 2-40s) left. What does that tell you and I don't sharpen my blades.
Edit: Changed 28 to correct number to 24
Carbide tipped, 10" x 60 tooth, Alternate Top Bevel, good for plywood and solid wood, Yes and about $100. Last Long Time. Can get sharpened for $15 - $20
Definitely carbide is the way to go! Remember you can also use it to cut aluminum plate, go slowly of course. This case was cut on the table saw.
