Hi all, Since my SAME has PTO issues that I do not have time to repair right now, I have found and bought a Universal 650DT Super.. It seems to run fine and all the functions seem to work ok, so it should work ok for the season.
Im in the process of changing fluids and filters. I do have a original service manual that is in English, but it is very vague with regular maintenance.
For instance the motor oil says use sae 30 or 40. Im going to use 15/40 diesel oil..
Also the manual does not represent the hydraulic system very well as the manual is for a 650M &651M.. Mine is a 650DT Super.
There seems to be a additional hydraulic system on mine that has a enclosed filter and steel tube line that runs horizontally along the lower right hand side of the machine. It appears to be a suction side of a hyd. pump mounted lower right front of motor.
The steel tube goes into the right hand fide of casing where the Manual I have says that's where the hyd pump is located.
What iam trying to determine right now is the oil used for this hyd system. There is a case, rear of the clutch enclosure and front of the gear box that seems to be part of hyd. system. There is a plug on the right hand side, just above half way that looks to be a fluid level plug???
Im wondering what type of fluid goes in there as there is very little in it ( way below desired level) I think??
Anyone who knows these tractors would be great to talk to Thanks
