Rjpuckett2
New User
Hello all. I'm new to posting on here so I'm hoping help is on the way. I have a MF 253 that over the past year has been losing steering. You could turn the wheel endlessly without much feedback. Easy but slow to react. I pulled the pump res off replaced the filter. Nothing changed. Took control box off and had local dealer do a rebuild. Put it on last night, topped off fluids and started it up. Looked in res. and can see fluid moving. When I turn the steering wheel the wheel begins turning on its own and continues to do so. It also often begins to jump back and forth violently. I have drained/bled the lines several times. Only a small amount of air came out and only after bleeding lines through about two quarts into a old hyd bucket. I'm checking the levels almost constantly. I've tried bleeding from every line on power steering I can find. I'm not much of a mechanic so what am I doing wrong or what is my next step? Any help would be appreciated. Also I see no signs of foaming etc since the air came out.
