Geo-TH,In
Said that the definition of insanity is doing the same thing over and over and expecting a different result.?
I think that applies to tractor tires too. Why patch them only to run over a nail, then patch them again, and again, and again, that's insane.
Sullivan tire removed the tubes from my Jubilee's tires. Cleaned the rust out of the rims, installed valve stems, put bead sealer on rims and installed slime for $24 each.
No more worry about flats caused by nails or thorns.
Now I have 3 tractor tires slimmed.
Let you know if I ever have any more flats.
I think it's time to do things a different way and stop the insanity.
$24 is cheaper than having tires foamed.
geo
