Don't forget that today the 9th of May is the Transit of Mercury across the sun. You need the old welding goggles like for electric welding type and you will most likely need field glasses or telescope. You must use heavy filters so you don't fry your eye balls!!!!! It will only be about the size of the period at the end of a sentence . I video tapped the transit of venus back seven or eight years ago. NEET! Look at the left side of the sun aroud 7:15 AM Eastern Daylight Savings. It will be visable for over SEVEN hours as it goes from the middle left down to about the five o'clock on the sun surface. Look at the illustration for a reference. It will look like a very small sun spot. Take a look if you can. The next one is November 11, 2019.
