My horses waist lots of hay over the winter which is turned into sopped manure. The bucket of blade does not work as well as I would like. I have been thinking a landscape rake would work with half the tines removed. I need a 5 foot wide to clear the rear tires. Prices seemed a bit much to remove tines for a try and have no other use for it.
I picked up a 7/16 thick 4" wide angle iron 5 foot long for 30 bucks and 16 tines at 4 bucks each. Still have to pick up the bolts. I will drop the blade off my three point frame and will be able to switch back and fourth from blade to rake. I drilled the 32 holes with my magnetic drill yesterday after noon. I'll have to wait until I have a mill clear to bore a 4" hole to weld the pivot pipe. I hope I can have it done some time next week.
