larry@stinescorner
Got two items for free the other day
a pressure washer with a cracked pump,but the motor starts and runs good.
and this air compressor .it works perfect,has no hose or regulator on it
It pumps up to 100 or so and shuts off ,it has a pressure gauge that works
I may need advice again on what I need to buy to hook up a regulator and moisture filter? to be able to use a paint sprayer?
three bolts hold the motor on the pressure washer, I took it off the frame
This old tiller I was trying to get going,but I dont want to spend money on the parts I need for it .I took the motor off to see if the motor from the pressure washer would fit,,but it doesnt fit.
Not only did mice make a nest in the motor,but where the belt is too,under the motor.The belt looks shot too.I decided to white flag the old tiller,the handle has been welded many times,and its not worth spending money for parts on it. If my friend Jim wants it for parts he can have it.,or its gonna go good by,,,lol The 6 hp motor from the pressure washer does run good too bad it didnt fit
