Gasket sealer
D Slater
Always used the victor head gasket on a IH C-175 engine but have a Fel Pro composite gasket I want to use up. It states sealer required. Would like opinions on the best sealer for that type gasket. Looks like ones used in the past that said use no sealer. Tried on line for a answer but mostly comes up with sealers to use when leaking after failure on a running engine. Thanks
Copper Coat in a spray can has always worked well for me. On Felpro you might have to give it a couple of coats.
