Ted in NE-OH
I need to mark the timing point on a flywheel. I've seen where some used parts are marked with a white marker of some type, what is it and where do I get it?
White-out.
Be sure to clean the area with a fast drying solvent like 'brake cleaner' before you mark the line.
A "paint marker" from the craft dept at Wallabee World works well.
<img src = "http://i5.walmartimages.com/dfw/dce07b8c-a156/k2-_b89ae910-9dfa-45ef-a17f-c64cb8c3597b.v1.jpg">
The timing mark is usually a groove. I mask off the flywheel and spray it with aluminum paint. The aluminum paint seems to reflect better than white.
(quoted from post at 22:29:42 04/09/16) I need to mark the timing point on a flywheel. I've seen where some used parts are marked with a white marker of some type, what is it and where do I get it?
sharpie brand makes a silver pen that shows up very nicely.. I use for marking cut lines for torch and plasma cutters.. it almost glows... seems like I also remember one of the Auto aftermarket folks selling a tape that has the degrees on it...clean the dampner and stick it on.
john
here you go...
http://www.summitracing.com/parts/sum-162591?seid=srese1&amp;gclid=CjwKEAjw86e4BRCnzuWGlpjLoUcSJACaHG55_MvMqIb4-w0yW_O3RKHEw0c8SjfXYgtV7DxDSJ8IXRoCh7zw_wcB
