Winch mount idea
I would suggest taking it vary easy on the one that has the 8000 lb winch on it! If you actually pulled that hard on the first layer of the drum it will probably fold the 2" tubing up or damage anything less than a Class 5 hitch. That's a big lever for 8000 lbs to work with.
I built something like that for my jeep, mounted a 2" receiver on the front bumper.
Also got the big plug and long jumper cables.
Just take it out and use it on the back if needed, or on the pickup,
even welded a receiver in my backhoe bucket.
Keep it simple. I easily remove , and store inside.
Good chance pic will get flipped when I use phone.
If it does rotate your phone.
Yeah it rotated 90.
