CenTex Farmall
I'm working on a new-to-me Lincweld 225 with Onan which I believe is a CCK. I haven't heard it run yet. It spins up ok on 24v but no pop, not even a try. Compression is there but I haven't checked it.
The spark appears to be weak. I cleaned and set the points at .020. I changed out the odd ball plugs for two good used ones I have. I pulled the flywheel and polished the mag lamination ends.
I'm showing about 10K ohm between the two plug leads, is that in the ballpark? How much compression should I get on a test?
I have an 4kw Onan generator, also unknown (was given to me) that is an OCCK. Would that engine bolt up to the welder if the one on it can't be revived? The welder is an earlier one and I'm not sure if it has a tapered crank or not. Would the OCCK have a tapered crank or a flange? Will the OCCK run at 3K RPM?
