Does a Minneapolis Moline big moe 500 have a sheer pin ?
Big Moe 500
New User
I was loading stone and when i scooped a load tractor got stuck, once I gained traction i heard a pop. Sounded like a sheer pin right side ,or did i really break her good?
There are no shear pins I know of. You broke some thing. Post this down on the Minn-Mo board. Those fellows can tell you faster.
Your Big Mo 500 is the same as a Four star farm tractor. So the internal parts should be mostly the same.
Nope, equipment doesn't usually have that, just implements. Sounds expensive! Something in the driveline let loose
