Farmall H Engine Specs
lucky2
I have a Farmall H that had the engine stuck when I dragged it home. Got the head off and things aren't looking too bad. Looked all over for Engine specs like how large the cyl bore can be before resleeving or ring gap, rod bearing gaps. I can find nothing online. Anyone have any idea where to find this information?
Besides the advice you will get on the Farmall Forum, the link below is very informative on piston fir, ring groove wear, etc..
There's several pertinent topics to click on.
Piston Rings
From I&T No. IH-8:
Piston skirt clearance .003-.004
Main bearing clearance .002-.003
Crankshaft end play .004-.008
Rod bearing clearance .002-.003
Rod side play .008-.012
Camshaft bearing clearance .0015-.0035
Sweet. That's what I needed. Thank you. I think I'm going to order some manuals too but at least I can continue enough to know If I need sleeves and pistons etc.
