guido
Hello
I used the new tool to cut the trim rather then remove it. Someone had stated that it would be loud, well you are right! Ear plugs were needed, and the tool work well. Tiles made in the USA. I learned two things while doing this project: One is that grout works great around the base of the toilet. Two that a shim between the water tank and the wall is an insurance against toilet movement, and a possible leak,
Guido.
Guido.
