Hopefully Last Utility Trailer Question
TwinCreek
Thanks for all the responses on my utility trailer questions! Hopefully this will be my last question. What brand and kind of paint do you like for your utility trailer? I will be painting it black and it will be stored outside. Thanks for your responses!
Most likely it will get scratched, dented, rust so use cheap rustolum paint. You will most likely need to tough it up many times
The last time I painted my trailer I used Industrial Maintenance Enamel from Sherwin Williams with a hardener added. That was in 2006 and the paint is still in good condition. I am told though Sher-Kem enamel is even better. With any paint the glossier the paint the longer it will last.
What I used on my trailer
http://www.martinsenour-autopaint.com/product-systems/pcc-premium-commercial-coatings
Its priced reasonable you can spray it are brush/roll it on. They have the thinners and hardeners that are comparable. I painted my tow truck with the Factory Packaged Colors deal 20 years ago it needs painting again it out lasted the factor paint job and a a $Imron$ job... BTW my Napa man told me it was made by Sherwin Williams true are not I dunno.
