(quoted from post at 10:08:45 11/22/15) Hello,
Determined got it right! It is used to locate TDC on Cat engines. I also made a timing pin for the pump. The tool makes it a one man job finding TDC. Does this method find #1 TDC every time?
Guido.
The first part of my answer to your question was yes as in yes your tool will always put #1 at TDC.(quoted from post at 19:22:51 11/22/15) Hello determined,
Just got back. What do you mean not necessarily! The pin will put the piston on TDC every time. The pump pin is to put the pump on #1 to time it to the engineThat is on#1 pump is a distributor type pump with six fuel lines. Does the pin always put #1 at TDC? that was my question. If not explain why. I think I know the answer..
Guido
When cyl #1 completes the compression stroke and reaches TDC(quoted from post at 09:52:16 11/23/15) Hello determined,
The pin will ALWAYS put #1piston @ TDC, BUT not on the compression stroke every time. You
need to take the valve cover off to verify that. One and six are companion cylinders, But
180* apart in the stroke cycle.So if one is on the compression stoke. #6 is the blank
stroke. Fill in the blank................
Guido.
(quoted from post at 12:20:25 11/24/15) While on the topic of 6 cylinder engines.
What engine am I working on in the shop right now.
-6 cylinder
-Firing order 1-4-5-2-3-6
-North American
-4 stroke
-Gasoline powered
-150 HP
(quoted from post at 23:21:58 11/24/15)(quoted from post at 12:20:25 11/24/15) While on the topic of 6 cylinder engines.
-6 cylinder
-North American
-4 stroke
-Gasoline powered
-150 HP
I believe that would be a Lycoming aircraft engine.
(quoted from post at 13:42:51 11/25/15)(quoted from post at 23:21:58 11/24/15)(quoted from post at 12:20:25 11/24/15) While on the topic of 6 cylinder engines.
-6 cylinder
-North American
-4 stroke
-Gasoline powered
-150 HP
Sorry hot wrench it's not a Lycoming but it does have a Marvel Schebler carb on it.
Not a Continental either.(quoted from post at 18:10:56 11/25/15)(quoted from post at 13:42:51 11/25/15)(quoted from post at 23:21:58 11/24/15)(quoted from post at 12:20:25 11/24/15) While on the topic of 6 cylinder engines.
-6 cylinder
-North American
-4 stroke
-Gasoline powered
-150 HP
Well, that was a WAG, how about a Continental boxer? They also had an odd firing order if I recall.
Hotwrench(quoted from post at 21:13:29 11/25/15)
Well, I was headed in the right direction anyway.
