Can someone recommend a place to get a low temp, say between 40 and 50 degree F, thermostat that will work with a milkroom type heater? What I have is a small electric heater with a fan in the pump house at my daughters. The heater has very crude adjustments and tends to cycle on and off a lot causing a higher electric bill than I'd like. The room is about 4'x4'x6' and the walls are either 2" styrofoam or 6" fiberglass. The ceiling is also 2" foam. The little Walmart type 1500 watt heater keeps it about 50-75F depending on when I check it. Way too warm for what I want. Someone must make a 115v thermostat that will work for me. I figured the guys here would know of a place to get one.
