larry@stinescorner
a free gift from harbor frieght
These are the greatest thing since sliced bread. They come in different sizes. I have a couple of the round ones and also a large square one with two magnets that is handy when dealing with larger pieces of hardware.
I keep one in my bead blast cabinet all the time. It not only holds small parts for blasting but it is amazing how much rust and metal filings it collects and keeps out of the glass beads.
(quoted from post at 08:43:22 11/13/15) I keep one in my bead blast cabinet all the time. It not only holds small parts for blasting but it is amazing how much rust and metal filings it collects and keeps out of the glass beads.
I like this idea!
I keep several of these magnetic parts trays in different sizes around the shop. Pretty darn handy.
[i:654c4848f0]More time is wasted from dropped hardware than anything else.[/i:654c4848f0]
Most of my wasted time is spent looking for the tool I had in my hands just a minute ago. Second most is looking for the bolt/nut I just had in my hands, so this still helps a lot.
I like how they store- just toss them up against a steel cabinet door! Just used the rectangular one in a live trap, for holding the bait. Stays put in the cage.
AND if the magnet on the bottom comes loose HF makes some two part epoxy that works well to fasten the magnet back. Of all the HF freebies that one and the 25ft tape measure are my favorite.
You will never own enough of'em once you get addicted to'em... I have them in all shapes and sizes. When I go under the hood of a car each fender gets one...
No, I just take it out every once in a while and blow it off with the air nozzle. A bag wouldn't hold up very long inside the blast cabinet.
Always wanted one, but to tight to buy one. Think you guys, you talked me into it the next time I'm in town.
While you have your wallet out get the big'N 2... They are about 12"X12" and hold tools well :D
They are multipurpose... I had the cluster out of a Buick when I installed it the temp and fuel gauge has swung 360 deg and on the back side of the needle stop... I used the small magnetic tray magnet to rotate them back around....
