breaker box
The minimun size box you can use would just hold that 1 two pole breaker and nothing more. Code does specify to plan for the future in which case if you have additional loads then more circuits in your sub=panel. Or a direct line from you existing panel if you have space for another two pole breaker , not adding any sub-panel. Feeding the welder from the existing panel you have now.
