Onan Generator
Robert Creed
New User
I've located an Onan Generator, Model 5CCK-3, E2236/1J.
Are parts still available since it is an older model? Do you have any idea how much to give for it? Thanks.
The CCK is the one every Onan collector is looking for.Cast iron block and will run fore ever if taken care of. Most are 120 only but a few are
120/240.Parts are out there. Need the full model and serial number to tell you what it is.Price depends on how much you want to spend. But most go
from free to 500.00. 500.00 is for one in great shape low hours making power.If they want more than 500.00 walk away.
A lot of them were used in motorhomes for 120 output. The instructions for 240 are under the plate that covers the wiring. I think they are as good a small generator as you can buy because they run at 1800 rpms, and have a large muffler. Much more "neighborhood friendly" than anything with a Briggs.
If the fancy circuitry stops working, you can rewire it in the conventional manner. New circuit boards are made from unobtanium.
