I have a 1965 ford in-line six that will start when the key is in the start position. When the key is released to the run position the engine dies. I thought the problem was the ignition switch. I checked volts at the resistor with the key at the run position and got 12 volts. I tested at the coil side of the resistor and got zero. I tested ohms from one side to the other on the resistor and got zero, don't know if that is the way to test or not.
I am thinking the resistor is bad?????? Yay or Nay any suggestions.
