Tool Talk Discussion Forum
Re: Shear strength of a bolt
Billy NY
09-22-2015 08:15:41
I can cite another example, different tractor, but same situation. Long time friend and families JD 2020. I don't believe they knew or were paying attention to what was in the M-F rotary mower, one of them is a bit hap hazard when it comes to tractors and equipment. Well it cost them, the sliding collar on the pto arrangement on one of these, 2 stage clutch like your 860. The sliding collar failed and it took a complete rear end disassembly once split, local shop did the work. There is no doubt that repeated shock loads being transferred caused the failure. We had the top cover off before it went to the shop to confirm what happened. That is one complicated back end of a tractor. They run grade 2's now though !
