lathe question
JOB
I want to join another forum, but have to answer a question. I don't know the answer, can someone give me the answer? I have put in wood Steel engine and metal with no
luck. Below is the question.
Two very different types of lathes typically used to turn two types of materials...one natural, one manmade. What are they ? (do not use "and" or comma...just name the
two, soft material first, one space between names, one word each. [If you have trouble with this email [email protected] but be prepared with a short bio on
yourself so I can tell you are not a spammer. ]
that was my first answer and the Registration came back rejected. I then put is wood steel, rejected. I then put in wood engine, rejected. ???????????
I used to hang out there a lot over a decade ago, guess it became a bit more elite since then lol. Back then it was just open conversation like here
I tried again and started from scratch and wood metal worked. Don't know why it did not work the first time.
You guys gave good suggestions though
