Tool Talk Discussion Forum
Re: Lathe chuck
DGinVT
09-10-2015 17:45:45
On the back side of the lathe chuck there shud be 3 screw holes. You screw in a bolt into each hole and slowly tighten each bolt which will separate the the chuck's back plate from the chuck itself. All my chucks have these holes. Make sure that you have carefully marked each piece for re assembly. Do not force any of the parts. A note of caution never use an air hose in cleaning the chuck as it will cause chips and other material to lodge in the scroll and jamb the jaws. Each jaw has its own slot.
