141 husky saw
Tom in Ga
Does anyone know what the coil to flywheel air gap should be on a 141 husky saw? I have set law mower air gaps with a sheet of paper but I don't know about the saw. Thanks, Tommy
I've always used a business card, then push the flywheel toward the coil, make sure it doesn't touch. If it does give it a couple more thousandths.
.012 works for most Husq. saws.
Be sure to run a resistor plug. A non-resistor plug fouls up the spark timing on some of the Husqvarna ignition modules.
The best thing I found to set them with is the Micro fiche cards. They are plastic and slide better than paper and are the correct thickness.
