Pressureize it yourself sprayer.
showcrop
What do you call the sprayer that you fill up with sixteen ounces or so of whatever you want to use, then pressurize with your own compressed air. This type does not have its own pump. I want to get one but haven't been able to find one because I don't know what they are called.
40 years ago a 30# freon bottle had a valve that screwed out. My dad would solder a
copper line to valve, put soap and water in bottle, pressurize with freon. He used it as
a portable pressure washer. The soap and water came out like shaving cream.
(quoted from post at 03:44:31 08/24/15) 40 years ago a 30# freon bottle had a valve that screwed out. My dad would solder a
George, I can go you one better. When I was kid there was a WWII military aerosol can around the house. I'm pretty sure that it was bug spray. I can remember that it had top and bottom halves that must have threaded together and a schrader valve for pressurizing it at the edge on top, and the outlet valve at top center. It was painted olive drab. I can't remember why I am sure it was single use.
I bought a couple of these happy with them
Chapin 1002 48-Ounce Multi-Purpose Sprayer
http://www.cometsupply.com/mp/CHAPIN/pm/CHP1002/r/ga/?gclid=COHT7IXuxMcCFckYHwod1pYA_Q
ss
