showcrop
I have a flatbed equipment trailer with two I believe 7700 axles Last time I used it I glanced back and noticed front right was leaned in pretty good. I stopped and unloaded the tractor and tried to move the tire. It wouldn't move. The tires on that side are worn badly on the inside. I Had just had it up in the air to work on the lights, and saw nothing wrong at the time. I have in mind to replace the axles, as they don't cost that much, and put a new deck on and get the frame blasted. HOWEVER, the time just doesn't appear to be coming anytime soon. Is there anything that would cause this lean other than a bent axle? There is no indication of a bend inward of the backing plate.
