crimp on wire connectors
dewy
wher do you get a good selection of crimp on connectors for 4,6,8,wire with little eye terminals and couplins all the stores sux and
carry the same thing 10,12 wire connectors with no selection and two in the box for 5 dollars,,,,,,,,,,,,,,,,,help................... thanks dewy
I have dealt with Spectro Wire in Moore Ok, for at least 25 yrs. They are great to deal with and reasonable prices too.
(quoted from post at 20:38:29 08/19/15) I have dealt with Spectro Wire in Moore Ok, for at least 25 yrs. They are great to deal with and reasonable prices too.
I live and work near this place, its a great place to go for all wiring needs, connectors, pins, loom and harness type stuff, insulation, splices etc. . It is very surprising what they have and can get.
Just as important as having good terminals is having a GOOD tool to mash them with.
What are you using?
I have bought these at NAPA and TSC from time to time. McMaster-Carr also stocks a good selection in pacs of 10 or 25. They also stock the tools to crimp. Just enter McMaster- Carr into google - they ship in one to two days to my house. Don't forget the heat shrink tubing to make a professional looking connection.
(quoted from post at 01:26:35 08/20/15) Just as important as having good terminals is having a GOOD tool to mash them with.
What are you using?
what Bob said... on large diameter cables.. battery, welding, etc I usually use a "crimping/swaging" tool and solder also... then cover with shrink tubing
john
I have one of those. For medium stuff I have one that looks like a bolt cutter.
For smaller stuff its hard to beat Klein, I have 3 of these, one bought used with the cutter ground off is handy for tight spaces.
http://www.amazon.com/Install-Bay-Crimper-Insulated-Each-IB1006/dp/B0068AEZE8
But this little one from Snap On is pretty handy too
https://store.snapon.com/Strippers-Cutters-Crimpers-Wire-Stripper-Crimper-Cutter-7--P648778.aspx
Good tools are not cheap, but should last you for life. Cheap crimpers cause a lot of problems that could have been avoided.
