Rods used to resize worn holes???
JD Seller
I have a set of carbon rods(I think they are carbon) you put them in a worn hole then you can weld around the rod and the weld will not stick to the rod. You end up with a round hole the size of the OD of the rod. I need some bigger ones of these. I can't remember what they are called. I am not having much luck finding them. Do any of you know what they are called and where I can buy some?????
JD Seller, can't help you with the rods, but can tell you how I fixed the tongue holes on my ole JD offset disk. I cut the hole out a little bit with oxy-act torch. Cut a piece of heavy wall pipe one quarter inch longer than the thickness of tongue. Let 1/8 inch stick out both sides equally. Filled in around the pipe with stick welder. Ground it all smooth. Have a perfect hole through the tongue, exactly the size I wanted for pull pin to fit through. Tom
I repaired the stabiliser bracket on my Ferguson 35 using copper pipe . Used in exactly the same way as the carbon rods , the weld won't stick to the copper and you are left with a perfectly formed resized hole . The only disadvantage is that you only have a few copper pipe sizes to choose from but then redrilling the new weld up from a smaller size afterwards is always possible .
Tom Thanks for the reply. I have done that as well. This hole is the bottom hole on a pivot on a smaller articulated loader. It is in a real tight place. I can reach through the top hole and weld the bottom one to size. Then I will cut the top hole out and weld in a hardened bushing in it. I can not get to the bottom hole well enough to weld a bushing in it.
You could use copper rod. I put copper behind some thin metal to keep the weld flush. I never tried it to keep a hole open.
JD;
If you find them post the source please. I've never seen large carbon rods. If I'm not mistaken even lantern batteries just used a stack of smaller rods.
Copper rods, tubing or fittings will work but the copper draws a lot of heat so you have to turn it up so you don't end up with a cold weld.
Contact David Shaeffield in Fort Gibson Ok. at 888-478-4558 He makes and sells kits of carbon rods for welding holes from 1/8 inch to 2 1/2 inch. Good luck
JD Seller;
One source of carbon rods is a welding supply shop where they are sold as air arc gouging rods or carbon arc gouging rods. I suspect that you're looking for larger diameter rods, though. In that case wrenchere85's answer is probably the information you need.
Stan
The local blacksmith from way back when I was a kid had a large supply of carbon rods he had salvaged out of dry cell telephone batteries. From the era of hand crank telephones.
JD,
NAC carbon products in punxsutawney Pa makes rods of
many sizes and lengths , they also have many broken
pieces ,all sizes. usually they will give you the broken
pieces if you pay the freight . Call 814-938-7450 and
ask for Bob.
george
Maybe I'm a bit slow but I usually have trouble welding in a narrow space, how do you get penetration on the drawbar when the rod is stuck down a little gap? Or is the carbon plug raised bit by bit? Even without a plug in the way I find it hard to build up the side of an egged out hole, I must be missing something in how to do this.
