504
Buddy wants to move a single horse,horse trailer,the bad part is it is two states away and he wants to haul it on my car trailer.(Re builder, no floor,bad tires.) So anyone know how wide a single horse is? Mine is the standard 82 inches between the wheel wells.
Hard to say since not one all fits into the standard. So you need to have soem one measre it to know how wide it is since as said many different ones made and so none likely to fit in the same mold
(quoted from post at 15:29:03 08/18/15) Buddy wants to move a single horse,horse trailer,the bad part is it is two states away and he wants to haul it on my car trailer.(Re builder, no floor,bad tires.) So anyone know how wide a single horse is? Mine is the standard 82 inches between the wheel wells.
Drive out, pull the wheels, go put on new tires and tow it home.
Not likely the horse trailer will fit between the fenders of your car trailer. The solution would be to remove the wheels from the horse trailer, place the axles on wood blocks tall enough to get the hubs ABOVE the fenders, and then chain everything down tight enough that it can't even wiggle.
Well, my single horse is only about 22 inches wide, but my married ones are a little wider as they are pregnant. Couldn't resist. Probably just put new tires on and pack wheel bearings and tow home. Tow lights might also be a good idea.
