MarkB_MI
- Location
- Motown USA
I came across this info yesterday of use to anyone who is using a later version of Firefox.
It turns out that newer versions of Firefox do something called "speculative connections". All you have to do is hover your mouse pointer over a link and Firefox will open a connection to that site. You don't have to click on a link. So if you're like me and move your mouse around the page as your browsing, you'll open up a bunch of links to sites you don't intend to visit. That can generate a lot of network traffic and computer activity, while it gives sites that track browsing activity a lot more info to work with.
It's fairly easy to turn off this behavior. The information below is from the Firefox support site:
In the Location bar, type about:config and press Enter.
The about:config "This might void your warranty!" warning page may appear. Click I'll be careful, I promise! to continue to the about:config page.
In the about:config page, search for the preference network.http.speculative-parallel-limit.
Observe the Value column of the network.http.speculative-parallel-limit row.
If it is set to 0 then do nothing.
If it is set to a different value, double-click on it to set it to 0.
I typically have several tabs open when I browse, and I've noticed a lot of activity on my router after I've been browsing for a while. I've also noted a ridiculous number of TCP connections when I run the (Linux) "netstat -t" command, and those connections close only when I close Firefox. Since I changed the "network.http.speculative-parallel-limit" setting last night, I've noticed a significant reduction in Firefox network activity. Highly recommended.
Turning off speculative connections in Firefox
