webster compressor?
jpcourt
New User
does any one have any idea what kind of Webster compressor I have/it s a big two stage inline with a big cast iron cooler between the cyl. I don1t have model number but have serial no.600259.
(quoted from post at 20:40:08 06/21/15) does any one have any idea what kind of Webster compressor I have/it s a big two stage inline with a big cast iron cooler between the cyl. I don1t have model number but have serial no.600259.
It's a Model 60. The first two numbers in the serial# are the model number for a Webster.
Thank you for the info.
Any idea what kind of CFM I might be getting , Also the HP rating.
Regards,John
(quoted from post at 12:51:41 07/03/15) Thank you for the info.
Regards,John
Dang, I used to have the manual for that. I believe it is a 2-3hp pump. You would be looking at 8-10cfm or thereabout.
If I had the bore and stroke of the LP cylinder I could tell you for sure.
