A question for the Dodge truck peoples
I have a 1/2 ton 2011 Big Horn. There are multiple trailer plug ports on the rear bumper. One is the flat-four style, the other is the 6 point with one more in the center. I want to put an electric brake controller on it so I can haul things on a trailer. Is the truck equipped with the so called "plug and play" wires, or will I have to run a wire from the cab to the bumper for the brake wire?
Many thanks
You will need the dodge pigtail for whatever controller you buy....mine came with the truck it was in the glovebox. Any trailer sales place will have the pigtail. You wire it to the controller and then plug it in under the dash
I have an 05 Ram 2500. It came with the wiring plug under the dash. When I bought my brake controller, they needed to know the application to send me the correct pigtail. Everything plugged right in and worked perfectly.
