Hello all. I have a ts-5 15.6 cfm compressor that ran for an unknown time last nite, with contacts stuck shut on cut-off switch, & safety valve blowing. I had strung extra hose to shadetree job trying to beat the heat. no leaks, could hear compressor kick on-off only when air was used. forgot to shut off air valve & switch as I normally do when I leave shop, left tools, called it a day. when I found it this AM, tank was warm, lower compressor also, but no need to pull hand away. my plan today is to replace switch, change oil, drain, thanks for any other input? wait & see I guess.sure hoping for little damage. this unit operated great.
