lastcowboy32
I've seen them, and they're so tempting.
Right now, I have a few things that I need to do:
Braze a crack in a thin-walled cast iron casting (steering box on an old Ford 640 tractor)
Braze the exhaust manifold on the same tractor
Cut some holes in small thin (1/8" max) metal for welding fabrication. (By the way, I just bought a 109 dollar wire feed flux core welder from harbor freight...not bad)
Anyway, is there any hope of one of those little outfits doing the trick? I understand that the oxygen only lasts 20minutes and costs ten bucks. Even if I had to buy canister of oxygen for each of these jobs, it's still worth it.
Anybody use these? Any thoughts, limitations, utility?
Thanks
Thanks
