Donald Lehman
Finally got around to putting the new air compressor pump on the tanks. NOTHING from the old pump setup fits or will work with the new compressor, of course. Got the new mounts pretty well made (after several false starts) and will be able to weld that together tomorrow. The outlet on the pump is on the opposite end of the old one. The pulley on the new pump is a couple of inches larger in diameter than the old one. It's a double pulley, the old one was single. So not only do I have to get a larger motor pulley, I gotta spend the money for a double pulley and then buy matched belts.......................................Shall I continue or do y'all get the jist of it................................(smile)
