Impact gun lube
JD hunter
New User
Have a Black and Decker 1/2 inch electric impact gun model 2670 . Need to replace the impact head grease which lists for $89 on B&D parts in a 4 pound can. Is there another grease that will do the job. Gear grease is more than value of used tool! Any suggestions? Thanks
I've always just used a good grade of wheel bearing grease in all of my impact guns. I've never had a problem with any of them.
I've got the little grease gun for air tools or needle zerks, I put whatever grease I have laying around, usually its that sticky red grease, or moly type
(quoted from post at 09:30:19 06/25/15) Have a Black and Decker 1/2 inch electric impact gun model 2670 . Need to replace the impact head grease which lists for $89 on B&D parts in a 4 pound can. Is there another grease that will do the job. Gear grease is more than value of used tool! Any suggestions? Thanks
I use Ingersoll-Rand # 105-4T I get it off one of the tool trucks that stop by the shop..
How about CV joint grease. Was in O'Reiley's yesterday and just happened to notice it. Bet that would work (didn't check the specs) or get something with Moly in it. They have grade 2 in a tube with Moly there too. That will work for sure.
