ford throw out bearing return spring
HELLO, STILL LOOKING FOR INFORMATION ON CLUTCH THROW OUT RETURN SPRING,
IT LOOKS LIKE THE 9N SPRING , BUT IT IS ONLY 3.75 INCHES HOOK TO HOOK.
ANY INFO FOR THE CORRECT PART WOULD BE MUCH APPRECIATED !!!
<image src="http://forums.yesterdaystractors.com/photos/mvphoto22752.jpg"/>
Can't you use an other spring,..does it [b:4185a3ecea]have[/b:4185a3ecea] to be the one in your pic?
So what is this, about the 15th post you've made on all the different boards about this?
You have been given some good advice on other posts about either using a different spring from something else or modifying a 9N7562 spring which the parts sites says it is.
You can keep looking for this spring and leave your tractor laying in a heap of parts or get creative, make something work and get your old BalMar back together again.
Or have a custom one made - if you have big bucks or are OCD.
It's just a darned old spring for cripesakes.
click here
OCD IT IS!!
YOU CAN NOT MODIFY THE SPRING, THAT IS WHAT GOT ME HERE!!
ONE WOULD THINK THAT SOMEONE IN THIS COUNTRY WOULD HAVE THE CORRECT SPRING !
I TRIED TO ADJUST ONE SPRING BECAUSE IT WAS 1/16 LONGER THAN THE OTHER AND IT WOULD ALMOST EXIT THE MOUNTING AS I REVERSE BENT IT IT CRACKED AT THE HOOK !!
AND THAT IS WHEN THE SEARCH STARTED .
