Portable light weight plywood cutting table.
Geo-TH,In
I use an old ping pong table to rip plywood on, but it old's and not very level. So
I got the idea to make a 4'x8'frame out of 2x4's. 5 inch corners out of 4x4's and
drilled a 1 1/18 inch 3 inches deep hole for 3/4 inch pipe to slide in. Plan to cover
it with 3/4 inch osb. I wanted to be able to easily remove legs and stand up table
along wall when not in use. May need to put a cross supports in middle. See how it
works first.
Now, I need to know the technical term for a circular saw guide. Mine is in two 4 ft
sections that can snap together making it 8 ft long, but is next to impossible to un-
snap. I use a c-clamp at each end to hold in to plywood. Looking to buy a better one.
So what do you call them and where did you get yours?
That looks better than what I have. It appears to have screws to attach the 2 4 ft sections together and not a bad price. Glad I have amazon prime. I can carry the 2 4 footer sections in my truck tool box too.
Don't use it often, but nicer than trying to run a 4x8 sheet of plywood through a table saw and it hard to put a table saw in tool box.
Many thanks.
I have something like the one you posted, but joining the two 4 ft sections is a Royal PAIN. I think yours is better. After making this post I found something on Amazon, but it can't be taken appart, and a little pricey. I like the way it clamps to the plywood, but I won't use mine much, so what you posted I think will be much better. I may even try to make the piece that joins the two sections together and use my old one.
4 ft and 8 ft edge
I throw a double size heavy duty pallet on top of a couple sawhorses. Good flat support, and the flat pallet boards support the saw cut. Keep a choice pallet just for that purpose.
That's a good idea if I could find two 4'x4' palllets the save thickness I could put them on top of my framework, thanks.
