Geo-TH,In
I use an old ping pong table to rip plywood on, but it old's and not very level. So
I got the idea to make a 4'x8'frame out of 2x4's. 5 inch corners out of 4x4's and
drilled a 1 1/18 inch 3 inches deep hole for 3/4 inch pipe to slide in. Plan to cover
it with 3/4 inch osb. I wanted to be able to easily remove legs and stand up table
along wall when not in use. May need to put a cross supports in middle. See how it
works first.
Now, I need to know the technical term for a circular saw guide. Mine is in two 4 ft
sections that can snap together making it 8 ft long, but is next to impossible to un-
snap. I use a c-clamp at each end to hold in to plywood. Looking to buy a better one.
So what do you call them and where did you get yours?
works first.
