Centurion generater will not start.
Drained gas and put Stabil in after not starting. Couple months of not starting. Tried starting with ether,Got low oil sensor. Carb is scary looking with wires. Thanks for any help. Bypass low oil shutdown somehow?
Don't be afraid of the carb, just note where the wires go. Couple things to look for in the carb are stuck needle valve, stuck float, residue in the main jet, bottom of the bowl. Just ease the bowl off, clean everything up with spray carb cleaner. The wires probably go to a fuel shut off solenoid. Be sure it is clean and moving free.
The low oil sensor... If it is a low level sensor, and you know it has oil in it, unplug it, see if it will let it start. Once you get it running, go back and see what's up with it.
If it is a low pressure sensor, need to verify it has oil pressure before running it more than a few seconds.
