My geofurnace has done a great job this bitter winter. Lately it has kicked over to electric grid backup. When shutting down and later restarting it, it runs well, sometimes for days, sometimes for hours. Incoming water filter is clean, waterwell supply (a pump & dump system) seems adequate although my flow meter is unreadable due to iron stains.
One thing I notice is the water supply temp is only 48deg when it used to be around 54deg and the exit water goes significantly below 30deg when it used to hover at or above 30deg. Wonder if exit water line is freezing? I have never had the incoming water line to the house freeze (approximately 15years old). Could this years frost be deeper or the ground thaw be different. No other work done to the system for several years and it has been reliable heating or cooling.
If you have an idea what might be happening before I call my expert. IaLeo
