Foil Backed Commercial Insulation
Glenn F.
Do any of you know the r-value of commercial foil backed 1.5" fiberglass insulation? This is the type commonly used on large commercial buildings (or at least used to be). Does the thick foil raise the r-value at all?
Thanks
Glenn F.
I've never seen the 1.5" stuff but I did some basement insulating projects with the 1" stuff and that is R-6.5. I really like it and plan to do another project with it in my outside work room.
Glenn,
The R value of anything is 1/U. U is the conductance of a material. Normally 3.5 inches of fiberglass can have an R value ranging from 11 to 15 depending on it's density. R 15 is high density, special order and expensive. So 1.5 inches of fiberglass could be anywhere from 5.5 to 7.5 depending on density. I have many insulation wholesale supply places. That would be a good source to find out what your R value is. I'm going to say, 1.5 inches of fiberglass is has about the same value of ¾ of extruded urethane. Urethane for fire safety reasons needs covered fiberglass doesn't.
Aluminum stops radiant heat transfer which is different from conductance. There is no formula that I'm aware of for radiant heat transfer. However, IMHO, radiant transfer is very important.
When I build on an addition or remold, I like to put up 3/4 inch extruded urethane, which is coated on both side with aluminum. The urethane is cover with drywall. The 3/4 inch has an R of about 5, but the aluminum makes a great difference in stopping radiant heat loss and gain.
