Don't ask, but recoil start came apart on me - This particular starter has the recoil spring against the inside of fan cover, topped by a mylar washer, and then the cord spool goes on top of the washer. Then there is a screw which screws into center post of cover to hold whole assembly together. Any cute techniques to getting that spring coiled tight enough to drop into cover, and attach outside to notch in cover, and inside to notch in rope spool? Seems I don't have enough hands/fingers to get all the pieces together!
That screw came up missing, which probably caused the center post in the cover to break off. This was on a Poulan Pro 330, but same part number matches Electrolux and Husqvarna, so probably entire assembly is used on several brands. Got a new cover, and probably will epoxy old one back together as a backup...
