Pandora 504
Have a Stihl 034 that refuses to start. Checked all the usual,coil was weak,replaced it and now have good spark,compression is over 160 after 5 pulls .The carb was gummed up,I cleaned it and put new kit in it.It wont even run after putting a little gas directly in spark plug hole. New plug is good,runs fine in my other saws..Piston is scored slighty in ring area on the muffler side but it has great compression.. Flywheel key is not sheared,looks good. Guy who owns had put a 4 cycle sprark plug (Autolite 258) .Way too hot heat range ,melted the center out. Im using the correct plug now,great spark..Will not start or even sputter,what am I missing?? Thanks for your help.
